wavinwayne
- Joined
- Jan 6, 2005
- Messages
- 10,284
To me, a carb may as well be a nuclear reactor. Of all the things I've worked on over the years, carbs never made the list.The governor keeps the engine constant while the blades are engaged. When at idle with the blades disengaged, you're having a lean condition from a fuel blockage in the carburetor somewhere. This is a very common occurrence. You notice how I use the the word "occurrence" instead of "problem?" That's because it's not a problem if you like carburetors.
