- Joined
- Feb 22, 2021
- Messages
- 1,046
This one caught my attention. It’s from the Aviation Herald.
As an A320 pilot, it’s too coincidental to lose both, the Green, and Yellow hydraulic system ( separate, they do not share same fluid ).
Only way ( unless bad luck ) that can realistically happen is if the crew takes too long to turn off the PTU ( power transfer unit ) which would then cause the other , separate systems, to overheat.
If they did a go around with both hydraulics out, that’s a huge increase in workload.
Incident: Jetblue A321 near Raleigh/Durham on May 28th 2024, dual hydraulic failure
By Simon Hradecky, created Wednesday, May 29th 2024 18:49Z, last updated Wednesday, May 29th 2024 20:34Z A Jetblue Airbus A321-200, registration N956JT performing flight B6-369 from Boston,MA to Fort Lauderdale,FL (USA) with 83 people on board, was enroute at FL360 about 100nm east of Raleigh/Durham,NC (USA) when the crew decided to divert to Raleigh/Durham reporting hydraulic problems. The crew performed an approach to Raleigh's runway 23L but needed to go around, then entered a hold. The crew reported they had lost green and yellow hydraulic systems and needed to work out whether they had sufficient runway length for a flaps up landing. The aircraft landed on runway 23L at a higher than normal speed (about 180 knots over ground) about 70 minutes after leaving FL360. A replacement A321-200N registration N2044J reached Fort Lauderdale with a delay of about 6.5 hours. The occurrence aircraft is still on the ground in Raleigh about 15.5 hours after landing. The FAA reported: "jetBlue Airways Flight 369 landed safely at Raleigh-Durham International Airport around 11:20 p.m. local time on Tuesday, May 28, after the crew reported a possible hydraulic issue. Passengers deplaned on the runway and were bused to the terminal. The Airbus A321 departed from Boston Logan International Airport and was headed to Fort Lauderdale-Hollywood International Airport. The FAA will investigate." |
