Originally Posted By: WMW0505
Originally Posted By: Miller88
Originally Posted By: Chris142
Check the oil pan bolts where the exhaust is closest to. The heat tends to make them loosen and it looks like a rear seal leak
The 3 next to the exhaust on mine weren't even finger tight. Probably another 1000 miles and I would have lost one or two of them. Whoever had the oil pan off ... it was a rubber gasket, not factory cork, didn't tighten them.
I forgot the wrangler and Cherokee 4.0 had different exhaust set up.
I agree, if you can live with the leak just run a good conventional 10w30 and good filter for 3,000-5,000 miles.
How many miles do you have on your XJ? I miss mine and have been close to picking another one up lately.
Going to hit 206K by the end of the month
It's tired and has lived a rough life, though. Mostly an off road toy and serves as my truck currently so it has to tow. Lift, bigger tires, locker and a winch.
Awesome. Mine was stock when I bought it. When I sold it I was running 33x12.50's, front auto locker, and 4.56:1 gears. I replaced the 8.25 rear end for a Dana 44 from another XJ.
Mine took a lot of abuse too, looking back I'm extremely impressed it held up as well as it did.
I've only been looking at stock ones so far, not many left in decent shape.
Are your 206k miles adjusted for larger tires? You might have well over that if many of those miles were on tall tires.
I never changed the speedo gear for the bigger tires. So I'm putting more miles on it than I think I am. I have a front lunchbox in it, swapped in high pinion dana 30 since the low pinion dana 30 self destructed. Some day, it'll get 4.10 or 4.56 gears and a ford 8.8 rear end with disc brakes.
Many plans. This one I would like to turn into full time trail vehicle and get another unmodified one and keep it that way!
