Jeep WJ 2000 - Help removing a steering wheel with shaved tabs (can't use 2 jaw puller).
Hi ppl,
I am trying to replace my clockspring, but the steering wheel is stuck, REALLY stuck. Can't use a 2 jaw puller, as the place where is supposed to grip, is broken, so it just slides (I guess that's why the previous owner didn't change the thing). Tried using brute force, rock it back and forth and a mallet, but it does not budge. Soaked in WD40 overnight the last couple of days, nothing. Tried to heat the surrounding are of the spline with a heat gun, nothing. Strapped it and tried to use the me in the seat as leverage (has a tab broken and its vertical position is always full back) nothing.
I worry I could deform the sterring wheel at this point.
I was thinking of cutting and removing the clockspring with a dremel, and try to use a bearing separator in place of the clockspring to remove the steering wheel.
I also saw a page where they drill some holes and used a screw type remover, but I worry that it will just strip the threads as the metal is very brittle.
If anyone has more ideas or experience, please share them, I have no more ideas left.
Thanks in advance,
Pudu4x4
Could you drill some 1/4" holes through spokes in the wheel then use the steering wheel puller with a bunch of nuts and washers?
Here some pics on the situation:
Front view:
Left side shaved/broken:
Right side shaved/broken:
Strap thing I made trying to remove it (Imagine I was seated and pushing with my legs so my back would push the vertical support of the seat):
Hi ppl,
Thanks in advance,
Pudu4x4
I thought Jeep had a recall and free repair for this not too long ago? If so maybe you can get it repaired for free.
Get the puller on there the best you can and air hammer next to it. Put the torch on it under load of the puller also.
If you wreck it and get a junkyard until make sure to swap over the SKIM before trying to start it.
Air hammer with a punch bit in the center of the steering shaft with the nut loose. I dont like using this method because you run the risk of damaging the column but you are about at the point where you need a column anyways so not much to lose here.
  • Like
Reactions: D60
What are those two holes for at 3 and 9 o'clock? Fasteners or locating tabs coming off the airbag?
Get a 2x2 chunk of square stock steel, drill some holes through it to get fasteners through those offending holes, drill a hole down the center, weld a nut around the hole, send a bolt down the middle to use as a jacking screw against the column.
Your strap thing is cocking the wheel about 30 degrees down, so you're not pulling on it straight, which won't help.
Alright, you need a puller with a yoke. You can still use a 2-jaw, but you have to keep the jaws from splaying. You may have to drill the arms and use all-thread.
If you don't want to drill a quality puller, make jaws from flat bar.
Preload with a yoke and create vibration. It'll come.
This is Icon's copy of Snappy's CJ2000; dunno if the widest is wide enough which is why you may have to make something or modify a kit like this
edit: in other news apparently Yoko is still alive and she's 92?!?!
