Jeep painted over torx bolts
MA
Hi Guys,
I need the advice of someone smarter than me, my TJ jeeps doors don’t fit right so I’m attempting (and failing) to loosen the exterior brackets that hold the doors in place. They are t40 painted over.
So far I’ve snapped an impact t40, and stripped two other t40s (also ruining those holes in the process).
Any ideas?
Example:
-kehyler
The one that broke was a Sunnex, although I didn't remove the paint down in the torx slots. It's on pretty good...
Always dig all the paint out first. Failure to do so prevents full depth engagement. Imagine a long row of $100ea titanium screws on an aircraft. After 30 or 40 of them strip out from poor maintenance practices, the customer starts to get really angry.
I've found that the 'all one piece' Torx and Allen sockets are often substandard and will strip, round off or break in the middle. It seems the hardening is concentrated on the tip, and may or may not be done properly. I can't tell you how many I've destroyed. Even in the same kit, one size will fail and it's neighbor will hold up well.
Ain't it grand?
I just replaced $6k in hardware because someone used the wrong grease and it all corroded.
Looks like a swivel/universal in the picture also. Get the paint cleaned out especially from bottom as stated. Get as solid a connection as possible to impact gun like direct to anvil. Old school days we also learned to try and tighten slightly to break the rust etc if it started having that issue. Maybe something to heat the threads from inside.
Spray dust can upside down on the nut will make it really cold quickly and may help crack the bolt loose combined with other things listed.
Can you see the inside? is it rusted up a lot? Spray the threads inside fender with some Gibbs penetrant.
  • Like
Reactions: GON
Well, I've got the bolt cleaned out fully, & paint scored around the edge -- I tried with my $100 Koken attack driver. T40 bit twisted. T45 bit does not fit at all, so I think I'm using the right size. Felt the Koken bit giving way.
Maybe to melt the loctite, apply heat to just the head bolt through an appropriately sized socket?
Well, you used a good tool…and it didn’t work. The hole looks reasonably clean.
So, clearly, tool alone isn’t enough. clearly tool engagement depth is decent.
1. See if a Torx plus fits in there - it looks like it might be a torx plus.
2. You need some penetrating oil to help
3. You need some heat to help
