My jeep is now my weekend vehicle. After going to pick up my car monday, it was rather hot and of course going through slow traffic.
I get to the garage and my jeep was sitting a hair above the 212ºF mark. I quickly turned the heat on the whole way and turned the fan on high. I figured it would get the coolant moving? I hurry up and get my car started and drive it out of the jeep's parking spot (I store my jeep at my family's garage because there are too many cars at home so I swap cars on the weekend). When I got back in the jeep it was 235ºF. I quickly but gently on the gas put my jeep in the parking spot and quickly shut it off.
This is the 4.0 and not the 4.7 so not worried about dropping a valve seat but is there anything that I should be worried about from it reaching 235 degrees?
I don't know when the last time (if ever) the thermostat was changed so I'm hoping that's all it needs and will be the one I start with. Having done a thermostat replacement before on my dad's 4.0, it was easy. But the belt being in front of a bolt on the housing made it somewhat more difficult. Is it possible to loosen the belt just a smidge just enough to lift the belt a little and then re-tighten it? Is that process even worth it?
Secondly, I did not recall if I heard my fan going or not. I was too focused on getting that thing parked. Really hoping the fan relay and/or the fan motor are sound. Going to focus on one thing first, will get the multimeter out if necessary. If it's just the relay, fine. If it's the motor, I'm giving it honest thought of adding a GM 11 blade plastic mechanical fan and running the electric fan as a combo. Both can fit and it's already lifted etc. so I'm not worried about losing .1 mpg because of a mechanical fan.
