Jeep 4.0 PYB 10w30 UOA
Connecticut
This was a run of Pennzoil 10w30 conventional in my 2000 Jeep Cherokee 4.0L with 140,000 miles at time of sample. The OCI was 4,000 miles. This Jeep sees mostly short trips with the occasional highway drive. Make-up oil was 1/2 quart of Pennzoil Conventional 10w30 due to a rear main seal leak.
I'm very impressed with the iron numbers!
BlackStone Comments:
"JOSH: Thanks for the reminder on the rear main seal leak and the make-up oil you're adding. It might serve
to dilute metals a little, but that's not a problem. And if anything, with the oil you're adding, it might help you
run a little longer between oil changes. The viscosity was a little low in this sample, (but it was about the
same as last time, so that's not an issue). Wear metals are surprisingly good. Iron is much lower than it was
last time, but that's no problem at all. The TBN is still good at 2.7, so you should be fine with a longer run
next time. Try up to 6,000 miles."
Code:
OIL Pennzoil Conventional Pennzoil Conventional 10w30 Universal Averages
MILES IN USE 3,503 4,000 4,300
MILES 131,203 140,000
SAMPLE TAKEN 3/2/13 12/13/13
ALUMINUM 3 3 3
CHROMIUM 1 0 1
IRON 23 9 27
COPPER 2 2 4
LEAD 1 0 3
TIN 0 0 1
MOLYBDENUM 258 242 67
NICKEL 1 0 1
MANGANESE 0 0 1
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 1 1 3
BORON 89 73 45
SILICON 11 7 11
SODIUM 10 6 35
CALCIUM 2419 2273 2100
MAGNESIUM 18 7 124
PHOSPHORUS 787 709 723
ZINC 914 786 868
BARIUM 0 0 0
Values should be
INSOLUBLES 0.3 0.2
WATER 0 0
FLASHPOINT ºF 410 415 >365
SUS VIS 210ºF 56.2 56.6 59-68
cSt @ 212ºF 9.11 9.25 9.9-12.7
Fuel
Antifreeze 0 0 0
TBN 2.6 2.7 >1.0
I've been pretty happy with the Pennzoil Conventional in this engine. I run it in two other 4.0 engines in friends' Jeeps. It is the quietest oil I have found.
That is the lowest iron I have seen on the 4.0...something to 10w30 in this engine for sure.
Originally Posted By: 901Memphis
Moly is high though are you using additives?
I believe that's normal for SN/GF-5 Pennzoil conventional, at least according to the last few VOAs I've seen.
Originally Posted By: Donald
Looks good to me. Whats your plan for the leaking seal?
+1
How about Pennzoil High Mileage 10w30?
OR, DEFY 10W30?
I plan on replacing the seal this summer. I believe its either a rear main seal or the oil filter adapter o-rings, but I will know once I start working on it. I've been too busy with classes and work lately.
I'm not using any additives or a filter magnet, although I would like to use a filter magnet sometime in the future.
Wow just wow that may be the best 4.0 used oil analysis I've ever seen, at least currently anyway! Pennzoil conventional for the win!
Your 4.0 wears better than mine but it has higher miles too.
I was really curious to see if the 10w30 would resist shear better than the Pennzoil Conventional 5w30 but it appears the difference is not real significant, although it was still a smidge higher and went an extra 500 miles. So a difference, but not much.
I think your steady use of Pennzoil conventional may have helped, all that constant moly has eventually yielded you a phenominal iron number. I'm a big fan of Pennzoil conventional SN in the 4.0 and would probably run it exclusively if not for a stash to get through...one of the downsides of a stash.
I was surprised as well with the shear, but the TBN was a bit higher on this sample and I ran it for 500 more miles so that is definitely a good thing.
I would like to do some used oil analysis on the other Jeep 4.0s that I service, and compare them to these results.
Wow! That's some low iron for a 4.0!
I want to get the Pennzoil Conventional in mine pretty soon! I will try to pull a used oil analysis of the RT6 when I drain it.
Also looks like piston skirt failure is not in your future - which is good, of course.
Don't jinx it haha.
Looks great. I can't wait to send mine in next month. I just hope the few -15*F starts didn't mess with my iron wear.
I just messed a little with the viscosity calculator. The 1/2 quart top off of 10w30 would be enough to boost the 5w30's kv@100 from 9.11 to 9.23. Since you ended up with 9.26 on the 10w30 to which you added half a quart, my conclusion is there is no real shear resistance advantage to the 10w30 over the 5w30 with Pennzoil conventional, at least not in this engine.
The 10w30 still has a little bit higher HTHS though. I believe next winter I'll just go ahead and run the 5w30 again, and be sure not to run it too long, 3k maybe.
