Just picked up a LX266 to use for miscellaneous yard work after selling my ZTR to switch to a robotic mower. It looks great. As any used vehicle, I want to change all the fluids and such.
This transaxle seems interesting.
There are two drains, two fills, an internal filter and a claim that for the two sides of the unit “Oil will not flow between compartments.”
https://files-us-prod.cms.commerce.dynamics.com/cms/api/jhddjbbnpf/binary/MA2oic
Had to get a first mow in today before rain this weekend and before I got it hot I noticed the reservoir was overfilled. So in my ignorance and just unscrewed the little black fill plug and let it drain out until the reservoir was at the full line. Also the fluid clearly flows from the hydro side to the gear side.
I know what the “official” paperwork says but it seems that if I open the gear side fill plug and pour down the reservoir to fill, then it’ll just push air out the gear side fill plug and maybe require minimal purging. I’ll still purge of course.
Note: the JD has a remote elevated reservoir, not a transaxle mounted reservoir.
Am I completely off base?
Thoughts?
Thoughts?
