This is a 1992 LX178 I’ve had for a couple of years. Today while mowing, I switched from going reverse to forward. Just as I started going forwards, it randomly spat out black smoke and shut off. When I restarted it, it runs really rough and blows out black smoke.
Oil level looks fine. I’ll check the antifreeze tomorrow morning once it’s cooled down. Oil and coolant are checked before use each time and both were level and looked normal today as well.
I replaced the Mikuni carb with an Amazon chinesium one and no change. It’s down on power, idles rough and wants to die to low idle. PTO engages the blades barely. Throttle is adjusted correctly per FSM.
Not sure what’s going on here. Any thoughts and guidance on troubleshooting would be greatly appreciated.
