I would clean the OE carb first along with the fuel filter change. Those off shore cheap knock off carbs are very hit or miss.
Thanks. I do believe that fuel delivery from the tank to the carb needs investigation. Is my plan to completely empty the tank and vacuum it out sound, or am I at risk of blowing up my shop vac? Luckily there is no urgency to this project. The battery appears to be toast so I may just get a new one on my next trip to Walmart.I would clean the OE carb first along with the fuel filter change. Those off shore cheap knock off carbs are very hit or miss.
Sorry - I meant after the tank was empty and fully dry. There's a fair amount of grass and other stuff in there.NO SHOP VAC TO DRAIN A GAS TANK. Unless your looking to meet your maker and make the evening local news.
Tank under the seat just use some compressed air. not too much pressure, and let the old gas come out at the fuel pumps inlet hose connection. New filter will finish job.
A few years ago, I began mowing my wife's Aunt's lawn with the Aunt's circa 2017 John Deere Z535M which was only used sporadically before I started using it. It was surging pretty bad when not under load. The only things I did to remedy it were to install a new air filter, put Seafoam in the gas, and run only 100% gas (no ethanol) in it. The surging went away in one mowing season...The good news is that it starts easier every time I visit. The bad news is that the B12 doesn't seem to have done anything..
If it has a fuel filter, it wouldn't hurt to replace it. If not splicing one in would help. An old guy that works on lawn mowers near me said to always check the float bowl as it may have crusty junk in the bottom. Now that seafoam has cleaned up the fuel system it might get sucked up into the carburetor.Yesterday I had a look at the MIL's John Deere LA110 lawn tractor. I don't believe that it had been started in three years, possibly four. It had gas in the tank and caburetor the entire time.
Step one in the process was to connect my Gooloo 4000 jumper battery. There wasn't even a click on the first go. After pressing the boost button on the GooLoo it started turning over. After seven or eight cranking sessions it actually fired. Suffice it to say that I was pleasantly surprised.
Step two: checked the fuel level and found it to be pretty low which is a good thing. I had brought along a battery powered transfer pump but hadn't bothered to check the battery status. You all know how that ended up.
Step three: dumped in a healthy dose of sea foam. Initially the engine wouldn't run without full choke. Later it would run at full throttle but was surging or seeking.
Step Four: spiked the old fuel with new 90 octane E0 at an estimated 3:1 ratio. After a few minutes of this mix it would run at mid throttle, still surging. Took it for a few laps around the lawn at this point.
Step five: went over the next day and fired it up again. It is starting much easier now. It can go down very close to the lowest throttle position without stalling and seems to run very smoothely at low to mid throttle. It still surges at full throttle, be that stationary or when driving. Seems like we have a fuel delivery problem.
Step Six: spiked the fuel with even more Seafoam. Having this soaking in the system is probably a good thing. Tomorrow I plan to fire it up again and move more fuel through the system. Any other suggestions at this point? Note that someone was under the hood in 2020; it's had no attention since then.
