Hi all,
Looking at my manual's instructions for jacking up either front end or rear end of my used 2005 4wd highlander and it says the following:
"When jacking up the front wheels, release the parking brake and place wheel chocks only behind the rear wheels. When jacking up the rear wheels, place wheel chocks only in front of the front wheels." Later it says "when jacking up only the front wheels or only the rear wheels, place wheel chocks on both sides of the wheels touching the ground". Finally it says: "when lowering the vehicle with front wheels jacked up, release parking brake and place wheel chocks only in front of the rear wheels. When lowering a vehicle with rear wheels jacked up, place wheel chocks only behind front wheels".
Questions:
1) Is there a reason the parking brake should not be engaged? Does lifting up the front end with the parking brake engaged put excessive strain on the parking brake?
2. Why the contradiction in placement of wheel chocks when jacking up the front wheels? First it says to place chocks only behind rear wheels and then later it says on both sides of wheels touching the ground.
3. For lowering the front end, not sure why it says to release parking brake as presumably according to the first set of instructions, the parking brake is already off. And so are you supposed to remove the chocks behind rear wheels (or from both sides of rear wheels depending on which of the two contradictory instructions you follow), and only have wheel chocks in front of rear wheels?
Questions:
