4WD
$50 site donor 2024
In this case 2x6‘s under tires is good backupGlad to hear you weren't injured. I wouldn't recommend getting under a car without redundant support in place. If I'm under a vehicle that's on jack stands, you can bet the floor jack is also there just in case.
Having 4WD’s allows me to do 4 ramps for level work like driveline lubes
Totally avoid stands … I’ll use two jacks even for brake pads …
When I rotate tires on the JLU … two floor jacks
