It's getting to be that time of year again. Good luck to all of the competitors.
Man this gets my heart pumping...
It looks like a video game, not reality. How does one memorize that much road to have the confidence to ride that fast??
Clutch-less shifting? What am I missing here?
Most Sportbikes these days come from the factory with Bi-directional quickshifters. Meaning you only need to use the clutch when pulling away from a stop, or coming to a stop. It still helps to use the clutch at low RPM to make the shifts smoothly. Anything above say 3k RPM, and you can just move the shift lever with your foot as usual, without using the clutch lever. On upshifts the bike will momentarily cut the ignition to briefly unload the gear-to-gear engagement, allowing a very quick upshift without letting off the throttle. On downshifts the bikes ECU will blip the throttle to match the engine RPM to the speed of the lower gear, allowing clutch-less downshifts.
I didn't see that info on Honda's site. Then again, they don't give that much info on the site. So, is this like a slipper clutch that "slips" up and down? The original slipper clutch was just for down shifts.
The sidecar racing is crazy stuff
