I've noticed that the radiator fan turns on for 5 seconds, then turns off for 5 seconds, then repeat every five seconds whenever the DEFROSTER is on--even when the temperature dial is set to maximum-HOT.
Whenever the radiator fan turns on, I notice the engine idle speed (normally, 800 rpm) spike to 1100rpm, then when the fan turns off--800 rpm again.
I'm going to assume that when the engine idle speed spikes, the AC compressor is actually engaging.
Isn't this ODD? I think so, for two reasons:
1. WHY would the radiator fan & AC Compressor need to be ON when I'm using the defroster on an ICY cold day, when the temperature dial is set to MAX-hot??
2. WHY does this happen ON&OFF, ON&OFF, every five seconds??
Car: 2007 Corolla, 43,000 miles. Everything STOCK.
