Originally Posted By: Mark72
MarkM66, The car does not bounce at all, I hear thumping coming from the back/trunk area, and thumping in the front which could be tie rods/bushings. Heck, might need an entirely new suspensin underneath for all I know. I'm having my tire shop check it out tomorrow before I let my mechanic have it so that I have more knowledge as to what exactly is wrong underneath it.
I don't think it was that good of advice and the price seems a little high unless we are talking replacing all 4 struts but still a little high, unless it include new strut mounts. I think you should have someone else look at it although I'm not sure if a tire shop would be best. You don't have signs that the struts are worn out, although they could very well be at their age.
The front struts have a cartridge insert and are about the easiest struts to replace and not a 3 hr job. Being cartridges a good price for aftermarket replacements are under $50 a piece. On top of that you don't have realign the suspension as you do after replacing regular struts. You do have to have a special tool kit but auto part stores rent those. The rear struts are conventional and have to come off like a normal strut.
You mentioned thumping noise from front and rear but that the ride isn't floaty. That usually indicates a strut mount or maybe even the strut cartridge needs tightened. With the cartridges replacing the strut mount or tightening the strut cartridge is easily done right at the top. The mount comes out before the cartridge and you can tighten the cartridge and replace the mount without even taking the cartridge out. The thumping could be caused by something else in the suspension being worn but from what you've said most likely it's bad strut mount(s) and not the strut itself.
Maybe the mechanic knows your strut mount(s) are loose/broken and is just going to replace all the struts and mounts and if that is the case the price wouldn't be so bad. I'd have someone else take a look at it first.
