Is this fitting for 98 lesabre radiator tranny cooler line?
stamford, CT
Picture.I'm funny order a new radiator soon. The transmission cooler lines in hat connect too radiator,the fitting looks rusted. Does the image above, replace that fitting? And does the fitting slide off the transmission cooler line?
GM Genuine Parts 8651654 Automatic Transmission Fluid Cooler Line Fitting
Ahhh ok.thought hey might slip off once detached from radiator.thief rusted,but its still solid..usable.so that means,ice have too buy a whole new transmission cooler line then?can't just replace that cooler line nut?
That fitting might be used for the cooler line at the transmission.
Sometime around 1990, GM went to a clip type connector at the radiator. I don't know if this change was across all model lines. THis is the clip type connector. There may be a black, plastic protective cover surrounding the clip.
Mine never had a clip.where it connects too radiator...both lines.its a hex nut thingy,just like in pic.
