If your having an issue with a Ring Doorbell another brand most likely will not work any better.
Ring is a good brand and most issues are usually tied to user issues in setting it up and most of all your wifi signal. Follow Spams3 advice for sure, but you may also have a weak wifi signal. Its easy to check. There should be a place that shows your signal.
Ive installed hundreds of non ring doorbells, Honeywell and Alarm.com brand linked to security systems but have run into many homeowners with their own Ring and they had nothing but praise for them. I have found almost all the time it is user error in the set up or the wifi signal.
With that said, motion detection on these things are dicey at best. It is very reliant on where the device is and every home is different. They are also less sensitive in hot weather vs cold. In set ups where the person would be walking across the cameras field of view VS dead straight on, motion will be better picked up, if its in a high area with brick right next to it, it may not work at all in the summer walking straight dead up to it, vs crossing the field of view. Brick holds heat. motion doctor relies on heat of the body. Ect ..ect ... lots of variables but always thought maybe Ring was less sensitive to this but think I maybe wrong.
I currently use a Skybell on my own home because of a super slim design (and got it for free from work*L*) But its motion detection isnt the best, even after a remote tech support factory firmware update (they are aware of the issue) I would prefer a Ring but its too wide and even then, I dont think any of these motion sensors in doorbells are the best. But would be willing to give another super slim a try, dont think there are any out there.
Ps. if your router is a internet provided cheap router, time to hook up your own. A good super powerful (for signal) is a Basic Motorola AC2600 (MR2600) and at $100 cant be beat for range. (Motorola routers/modems is a Lenovo brand)
I try to avoid extenders if it can be solved with a proper router and placement. I have found this easy to do even in my 3000 sq ft home which has a perfect wifi signal in every corner of the home. For the fun of it and bargain price I just picked up a TPLink 4000 (Archer A20) for $109. Much more powerful in the sense it has 3 bands but the wifi is pretty much the same. I am close to 30 devices in my home now and was curious if it would make any difference, in what I dont know, everything works perfect with either router.
I get my 200 Mbps and over what I pay for in every room of my house pretty much with both routers, slight edge to the TpLink.
