Is there a moly grease that carries GC-LB rating?
South Dakota
I know normally a moly grease does not carry the wheel bearing (GC) NLGI approval, but are there any that figured out how to run Moly in a high speed application that got the GC-LB approval?
Most of the modern moly greases I've seen carry the GC-LB rating. Atleast here in Canada.
Few question before I give answers.
1. How high is the high-speed application? Any DN number?
2. Do you have schock loads - if yes can you qunatify them?
3. What is the main reason to search for molly grease?
I've heard Moly plates out in high speed applications. I had a guy tell me anything spinning faster than 1800 rpm would plate out and I'd roast my bearings.
Hi is right.
High DN rolling applications - especially needle bearing dont like moly.
I know that molly is hype now. Grase manufacture try to profit of it an introduce GC-LB greses with minimal % of moly but just enough to be on label.
In general greases with moly lower dan 3% moly can be GC-LB certified - and sell at premium product.
Back to my questions - What is your application ?Do you really need Moly?
It is not the rpm-s that determine usage of moly or not it is the speed factor Dn
http://www.skf.com/group/products/bearin...fill/index.html
http://www.klueber.com/ecomaXL/files/Lubrication_of_rolling_bearings_tips_and_advice.pdf
or just put it simple larage slow 1000rpm bearing can be subject of skiding in case of moly grease while small 6mm beariung can live at 10,000rpm
2. the beraing construction - needle rolling ,ball
3. material steel or ceramics
4.bearing construction/sealing etc
In general there are many factors - the simple mechanic rule is 1000....2000rpm
