- Joined
- Nov 29, 2009
- Messages
- 9,517
Do they make a longer version of this filter with the same specs?
Indeed, but the diameter is bigger.XG3614 is shorter that the 3600 and longer than the 4967.
My 2¢
I cant find this filter anywhere.XG4386
There's also the FE4386![]()
I was looking for the ultra. Amazon has them, but I'm reluctant to get them from there. Might be fakesoops, it appears they don't make an Endurance for the 4386, sorry![]()
That's it.Try an XG4386.
walmart is out of stock.That's it.
I believe the two filters mentioned in post #3 will still work. Yes they are wider but they should still work. Which vehicle? @Tkonrr used them on a Yaris so whatever you've got it should be ok unless the length somehow interferes with some components or the ground.Kawasaki 49065-7024 is my oem part number. Looks like an xg7317 will fit. Same diameter, but slightly longer. Update: I'm wrong the 7317 is a metric thread. My bad. Looks like the xg4386 that critic and slacktide mentioned is the only longer filter that will work.
Metric threads thoughI believe the two filters mentioned in post #3 will still work. Yes they are wider but they should still work. Which vehicle? @Tkonrr used them on a Yaris so whatever you've got it should be ok unless the length somehow interferes with some components or the ground.
The larger 3614 and 3600 sized filters have identical threads to the 4967 and 4386 sized filters. Nesterenko's post is spot on.
So then how on earth would those larger diameters work on a Yaris? It's not maybe, they'll fit, they have actually been used. @Tkonrr is not the first guy to verify they're ok.While all 4 share the same 3/4-16 thread size the 3614/3600 have a larger gasket diameter and would not work.
