I have heard that the Motorcraft 5w30 is a synthetic blend. Is this true? If so, what percentage is synthetic? It is $1.42 a quart at Wal-Mart. If this is true, this is a great deal.
Did you see that new GM 5w30 spec ?
That is the MSDS for Conoco oil destined to be sold in the Asia Pacific region .quote:
Originally posted by HolesInTheHead:
I think this is the MSDS for the regular Motorcraft 5w30. Up to 42% of unspecified synthetic.
I don't think this is what your asking but to assure you are getting a group II/III blend the Conoco or Phillips 5w30's for sure are as compared to the API SL GF-3 Motorcraft 5w30 and the maybe that comes with it .quote:
Originally posted by 427Z06:
So, does one have to assume that you need to get the SM, GF-4 Motorcraft 5w30 to be assured you are getting the Conoco syn-blend?
Thanks. That's what AP stood for. Do you happen to know the percent of synthetic in the North American MC?quote:
From what I've seen , the Motorcraft MSDS's are written by Ford anyway . The only way to obtain them is by fax but that MSDS , well the base components look very similar to the SL GF-3 Motorcraft 5w30 .
The "back label" references to synthetic base oil will probably be widespread with the GF-4/SM oils. The 10w30 grade will probably have many Grp I plus Grp III formulations.quote:
My local Wal-Mart also has SM GF-4 Motorcraft 5w30 which is now labeled Synthetic blend right on the front of the bottle.
