Originally Posted by ls973800
Originally Posted by PWMDMD
I just changed the rear differential fluid in my 2018 Pilot Touring....needed 2 quarts and found it on Amazon for a price that it didn't make sense to not use genuine Honda differential fluid. For transmission and differential fluid I'll probably continue to use genuine Honda fluids.
Your 9 speed transmission calls for Honda 3.0 or 3.1 ATF. Right now it ranges from about $33.00-$50.00 per quart usually. I don't think there is a good alternative yet for that fluid. I have a 2019 Pilot Touring but don't have to worry about the fluid for a while yet. I think they are calling for the first drain and fill around 60000 miles unless you tow?
There is a special procedure to check the level since there is no dipstick. The proper way right now requires a temp reading of the fluid within a specific range while checking the level with the plug out. I have heard of maybe having the car sit for a day or so and the replacement fluid in the same area to get at the same temperature as the car fluid. That way you drain say 3 quarts and put in 3 quarts. Haven't seen on any forums yet if anyone has done it that way. That is also assuming the level is/was at the proper level to begin with.
Holy Crap....~$37 a quart for that stuff, is Au an additive these days? It's a ZF box, surely there is an alternative out there.
https://static.nhtsa.gov/odi/tsbs/2016/SB-10086884-2280.pdf
While googling around I found that. Kinda ridiculous that they want you to use a brand new cover(cast/machined metal), bolts, and fill plug all to replace a potentially torn gasket. Honda kindof went off the reservation for that IMO.....
Sorry, didn't mean to drag this OT.
