Originally Posted By: Nyogtha
Originally Posted By: maxdustington
Originally Posted By: goodtimes
Many cartridge filters use plastic type end caps to pot the glue. That would be a good upgrade to the EG and TG and maybe they would have better centered caps with no loose glue.
If there was a problem with the cardboard end caps they would have changed them by now, they changed the abdv instead.
They also use the cardboard end caps on the TG.
What is the point in metal end caps if the media tears off them like a puro?
Fram Filtration certainly saw value in metal end caps when they (briefly) had the Carquest contract, manufacturing CQ Red spin-on filters as essentially EG's with metal end caps and often flush style BPV's as used by Champion Labs in some models, the CQ Blue spin-ons were similarly essentially TG's with metal end caps and same BPV variations.
From what I've seen, the CQ Blue and Reds appeared to be a Champ Labs design, with the Blue basically using the same media as a Champ Mobil 1 filter, and the Red using regular cellulose with metal end caps, like the recently posted Service Champ. Now that Fram & Champ have split up, if Fram started making a CQ Red, it would look like Walmart Tire and Lube Express or Super Tech, an Ecore. Not that there's anything wrong with an Ecore or an Extra Guard-IN SHORT INTERVALS! I don't care what Fram states, I'm not going past 5K on the fiber end cap filters, too many instances of bent media, leaking/off center glue jobs, etc. Now the Ultra is a different story...
