Ok, first off I would like to introduce myself. My name is Zack and I am a long time visitor to this site. I must state that I have learned a ton while reading these forums. I decided to join, because I have a little problem I would like some feedback on.
I bought my 06 Dodge Ram Hemi with 130k miles about three weeks ago. I checked it inside and out and everything checks out fine. Fast forward to the very next day, I go to check the oil and I noticed the pcv crankcase breather hose was disconnected! It was bent 180 degrees backwards. And the worse part: it didn't have a [censored] filter on the hose! The intake had a little one, but not the breather.
So basically, I would like some input on what to do now. I know I SHOULD take the valve covers off and remove sludge, etc. but I literally do not have the time or patience for that right now. I was thinking of putting some kind of cleaner in the oil and immediately change it. And maybe sea foam? I was also thinking of maybe getting a compression test done.
So far I have changed the pcv valve and re connected the hose.
What worries me is I have no idea how long the truck has been like this. I know during idle situations the breather hose sucks air, along with dirt in this situation, into the crankcase. The truck does not smoke at all and has plenty of power. Am I being overly paranoid?
