More fun for consumers to argue over..lol
Beta ratios have been around since just after WWII..
They were developed by Oklahoma State University by Dr. Henry Fitch. ( if memory serves ). For the US military as a way of rating specifically a filter which has been manufactured.
However, the usual beta rating is for a specific micron. Say 10. Or 5. Or 1. Or 6. Or 12. Or 25.
As the Fram paper says, you'll see a Beta ratio printed as B10=75.
B..means a Beta test was used.
10..means that is the micron particle size
75...means 98.7% efficient at the micron size particle listed and larger.
Now in hydraulics, they are using B10=200 (99.9% efficient)or even B10=1000 ( 99.99% efficient).
So a beta 200 or 1000 rating.
The reason you don't see these used for automotive use is because they are generally not required by automotive OEM's.
The testing takes a lot longer to do than the usually SAE test. You need the testing equipment.
And there are ways to "enhance" your results, even with a beta test. So the test is not apples for apples unless the tests are run under the same parameters.
