I've topped up coolant more than usual lately. The most likely culprit on these ls engines is either a head gasket or cracked head. I had the drivers valve cover off for a PCV issue a couple years back and the head was not the "Castech" one that is known to crack. But the passenger side could be.
It's the original 4.8 with 11,400 hours and I have a couple 5.3 engines as spares. If I just have the engine swapped I would probably prep one of the 5.3s with all new gaskets since it's sitting on a stand.
