I also posted this in Wheels and Tires, so if you've already read it, no need to continue.
I took our 2002 Sienna to my trusty mechanic for a check-out before oilBabe takes it to Dallas, TX next week to visit her brother, SIL and their new baby with our kids and her mom.
The van has a very intermittent vibration that may or may not happen during a trip. It might happen 1/2 hour into the trip, or may not happen for an hour or so, or may never happen. When it does, the wheel can shake severely, but not so much that one loses control of the vehicle.
Then, it goes away.
So I asked them to look at the van to see if anything is obvious, alignment, balance, broken or bent suspension parts, struts, etc.
They did the inspection and found nothing horribly wrong, re-balanced the wheel/tire assy and gave it back.
He mentioned it may be a slipping belt in a tire.
I really can't find much on a slipping belt on line, so I thought I'd ask about it.
oilBabe is taking the van to work today to see if the problem recurs. If it does, I'll swap two of the wheel/tire assy from her Camry to the van and drive it again to see if the problem stays or goes.
But other than this method, are there any tips or hints on how to track down such a fault.
Second, what is going on if there is such a fault.
Finally, we bought the van used, so if it turns out to be a bad tire, will Goodyear still warranty the tire, or are we on our own?
Then, it goes away.
