Short version: 1995 Ford Aspire ~103K miles. Seems to have a miss from time to time at hot idle. It does not occur consistently, but when it is happening it is at a 6 to 10 second interval.
Further details: My girlfriend took possession of the car at 56,000 miles. Before that, it was her aunt's who basically decided she didn't want a car anymore (secretly I think she was fed up with this car but that's another story). We have the full service history since the car's been new. Since 56,000 I've done the basic stuff here and there that is within my (limited) skill set, and everything else has been done by a local (fairly reliable) shop.
The car has never been as smooth or quiet at idle as other vehicles but makes it from point a to point b. A few months/3,000 miles ago I had some lack of pickup from a stop, sputtering when I was getting going and had been noticing that the rough idle from time to time was more a consistent miss/sputter after about 30 minutes of driving, but only when at a full stop. I installed new cap and rotor but the miss/sputter didn't go away (the lack of pickup did). I probably should have continued and just done the plugs and wires but I assumed they were a little too new to be causing the problem (25K to 30K on the plugs and wires) so I decided to ask the shop I use to take a look. They regapped the plugs and asked me to drive it for a while and let them know, for about 200 miles this worked, but the miss/sputter reappeared after that. Back to shop, installed new plugs this was about 1,500 - 1,800 miles ago, and I am noticing that the miss seems to be returning - no where near as bad as before, but I'm thinking it may continue to get worse with time.
Compression was checked and was told it was correct (within range) for the vehicle - unfortunately I did not get the exact reading.
My thought it I should check the plug gaps and go from there, maybe replace what the shop put in with the same brand plugs I had before (NGKs), only because I know those went 25K, but I feel like doing this I might be masking the problem for a few thousand miles rather than getting to the cause of it. Any advice on how to proceed/what could be causing this?
