Intake vs. exhaust valve diameter
Descending piston has to pull air/fuel in; I think the fancy term is that there is but atmospheric pressure to fill the void made by the falling piston.
But when the piston is moving upwards, it is a positive pressure which can well exceed atmospheric pressure. Actually its well above that, what with the hot and still expanding gasses.
Net result: much easier to get air out of the engine rather than in. Since one is limited in valve size, it is better to sacrifice exhaust diameter.
Now, add forced induction and things change. But even still, I bet there is higher pressures in the exhaust than in the intake.
Chris142.....Nope. there is a rule of physics called the conservation of mass.
Supton: Nah. The piston acts like a pump.....it will pull any air in that it needs. If it can't, you'll see your air filter or intake collapse. Any and all ambient atmospheric pressure is irrelevant.
Just a theory, I have no why to prove it...but I think the exhaust valve is bigger because exhaust gases are MUCH hotter than the intake charge. As the temperature rises, so does volume. So there is actually a larger volume of gas that needs to exit than what entered. Hence, the larger exhaust port.
Good point about exhaust valves being smaller due to heat issues. I'm sure much of the heat is being removed through the small sealing surface area; and a larger diameter valve is going to have the center all the hotter. That said, sodium filled exhaust valves is an old trick to aid heat flow out of the valve into the head, I think it dates back to the 60's.
Piston certainly acts like a pump, but it's not that good. 15-20psi at idle/decel? That doesn't take out the air filter nor any lifters, and clearly leads to very little air/fuel in the cylinder.
Was reading the other day about how some of the earliest engines used a very weak intake valvespring and *no* camshaft, relying solely on atmospheric pressure to open the intake--apparently this was part of the impetus behind the F head (intake valve in head, exhaust in block).
In general, engines exhibit better performance when intake valve size is optimized. Exhaust valve size is not as critical.
It's not unusual for the intake valve to be much larger than the exhaust valve. And the result is better volumetric efficiency.
Interestingly, this (intake valve area vs, exhaust valve area) formula works well for Turbocharged/supercharged engines also. Audi, for example was using engines with 3 intake valves and 2 exhaust valves. Ford used 2 intake valves and one exhaust valve in many engines with good results. Also, some 4 valve diesels use intake and exhaust valves that are very close in size.
There have been some experiments with extremely high RPM F1 type engines trying to use intake and exhaust valves that are quite close in size. Guessing this is just simple geometric size optimization.
It's easier to get the exhaust gasses out than to get the intake gasses in.
Keep in mind that the exhaust valves start to open BEFORE the piston is on it's way up for the exhaust stroke, and cylinder pressure is still very high. Leading to efficient evacuation of the cylinder. Many don't really understand that the piston does not force most of the exhaust gas out. Most of the exhaust gas pressure escapes the instant the valve opens. The engine does not do much work pushing out the remaining volume, as the pressure is quite low in a non turbocharged engine (with a relatively free flowing exhaust system)
Originally Posted By: mjoekingz28
Hello. Just wondering why intake valves have more diameter than exahust ones.....
Thanks
With only so much surface area on the top of the combustion chamber for valves, it works out better to give the intake more circumference than the exhaust, because the intake is limited to a much lower pressure differential.
Its about maintaining equal mass flow. The exact same mass of air/fuel comes in the intake on each stroke as goes out the exhaust, but the stuff that goes out the exhaust is at much higher pressure and temperature (PV=NRT, but "T" has gone way way up due to combustion and the cylinder volume at BDC is exactly the same, therefore pressure is far higher).
So the exhaust valve can be smaller and the very high pressure differential still pushes all the gas out thru a smaller valve opening. On the intake side (without forced induction, that changes the game...) the absolute MAXIMUM pressure differential to push the air/fuel into the cylinder is sea-level atomspheric pressure (about 14psi). In reality its less, because the cylinder is NOT at perfect vacuum after the exhaust stroke, and unless you're at sea level, the outside pressure is less than sea-level atmospheric, and with the throttle partly closed the intake manifold pressure is even lower still.
Originally Posted By: robertcope
I've never seen a motor with larger exhaust valves than intake.
Good link that talks about it: http://www.hipermath.com/engines/exhaust_valve_size
robert
Me either. Without forced induction a piston can only work with the 14.7 psi (or less) at sea level pressure. Even of the piston creates an absolute vacuum on the induction stroke the pressure difference won't exceed the pressure of the atmosphere at the location the engine is operating.
The other big factor is that the correct exhaust port size to maintain proper exhaust velocity and scavenging is always smaller than the intake side of things.
There is no reason in the world to have an exhaust valve that is oversized for the port it is feeding.
Oversize the valve with a correct port, and you get nothing and potentially lose something.
Oversize the valve and port, and you have an engine that's a total dog.
That's the purpose of the 3V heads in the Ford engines. The single exhaust valve allows for high port velocity at lower rpms, to give the engine the widest, flattest torque curve possible.
Supton is right. 1 ATM is about 15psi. that's it. At the speeds the piston descends, getting air in with no more than 15 psi is hard. air is squishy and does not act like water under pressure.
Having built more than a few 350+ hp mouse's with mild cams, if you want to make power, then think of the engine as a simple pump. The ONLY force moving air into the engine is the atmospheric pressure. ( = 1 BAR+ varies with altitude; the column "weight" of the "bowl" of air we swim in
Any cylinder head layout has limited area to place an operational Intake and Exhaust valve AND the spark plug. Typically the intake valve area will be the limiting factor to achieve max airflow IN. as you only have 14-15psi "pushing" the air in. On the Ex side you are exhausting high pressure hot gasses which would require less valve area to evacuate the cyl adequately - THEN you have header scavenging to resonate "pull" the remaining gas out at the intake ex open overlap (yes both valves are open at the SAME time around TDC finishing the EX stroke. Now FORD has gone too far in the past with 351C heads and others so there is a tipping point where the exhaust will become too small for max torque at RPM. it’s a balancing act especially for a street engine were you want more than a 1500- 2000 RPM range of operation ( racing say 5000-6500) street torque peak tune to run and operation range at 3250-5250.
When the exhaust valve opens, cylinder pressure is 100+ psi, and the exhaust basically blows out, equalizing cylinder pressure to exhaust pipe pressure before or a little after the piston reaches BDC. Then the piston pushes the remaining exhaust gases out. Traditionally, the design ratio has been to make the exhaust valve 80% of the intake valve diameter, but lately, the trend has been more toward 75%. Then the exhaust cam duration is increased to make up the flow deficit.
30's.
And you can see this in the exhaust cloud, especially on four-cylinder cars.
It is always harder to pull vacuum then to build pressure. Look at any other system be it hydraulic or pneumatic, the pressure lines (exhaust) are always smaller in diameter than the intake or return lines. That is why the intake pipe is much bigger than the exhaust pipe. Valves follow the same principle unless the engine has other means to pre-compress the incoming air.
I never imagined a answer could be more than 100% wrong...
Atmospheric pressure fills the cylinder, large valve(and ports) lets air in more easily... Ever consider why a engine looses power at high altitude??? Less pressure...
Exhaust valve(and port) smaller, the fast rising piston and expanding exhaust gasses create far more pressure than will ever seen on the intake, even if engine is boosted...
Well too big of ports and intake valves can actually kill power if poorly matched to the cam and intended driving. In the old days for instance, the street Ford guys with a 351 Cleveland preferred the 2v heads to the 4v. Same went for the low and medium rise heads being preferred over the high rise and tunnel port FE heads. At some point big valves and ports really only matter for high RPM power. But broadly speaking, you are correct as long as the rest of the design and components mesh well as a combo.
