Insulation Q&A
MIchigan
I got some insulation that is 3-1/2" thick (2 x 4 width) but I'm going to install it in the basement floor joist cavities which are 6-1/2" deep. I'm wondering if I should fill the cavity 6-1/2" or go with 3-1/2". Or buy a thicker insulation.
What is the correct way of doing it?
Are you looking for energy savings or noise reduction?
You don't need to fill the entire joist with insulation. Just put one regular bat in the joist. I would leave an inch or two in between the subfloor and insulation leaving an air gap.
You should use spray foam in between the sill plate and the top of the cement wall in the basement. That is where a lot of cold air leaks into the house.
I see and sell a lot of houses. Most of them don't have insulation in the floor joists in the basement. I don't think you want it too cold down there if you have pipes down there, they're more likely to freeze.
Energy savings. Previous owners crammed insulation into the joist cavities and I know that's not the proper way to do it.
If spray foam isn't an option, another way of doing it is buying a 4x8 sheet of 2" closed-cell foam insulation, cutting it to fit the rim joist cavities, and using the low-expanding Great Stuff or the acrylic Dow foam to seal around it. It's more time-consuming, but will do the trick.
Cramming insulation is how it was done back in the day. My house has that since that's what they could do cost/time efficiently that did something rather than nothing.
Assuming you are using fiberglass batt insulation, it's a poor choice for floors (also a poor choice all around, but that's a different conversation). There are three inherent problems with fiberglass batt and floors.
1. Fiberglass batt will almost always fall down. Gravity is relentless and constantly pulls on the fiberglass, and air gaps between the subfloor and insulation not only negate the insulation value, but can be dangerous.
2. Fiberglass batt has to be in contact with the subfloor in order to work properly and to help prevent the spread of fire. See #1 for the reason why it doesn't always maintain contact.
3. In order to keep fiberglass batt in place on a ceiling, it ends up being compressed around wires, ducts, pipes and the wire supports used to keep it in place. Once you compress the insulation, the fiberglass looses restrictive (R) value.
The very best you'll get by using fiberglass insulation on a floor is grade III, and that's if you're lucky and skilled at installing fiberglass batt.
Leaving an air gap is an extremely bad and unsafe recommendation. Not only is it a fire hazard, but gaps negate the R-value of the insulation. Having an "air gap" would cause the installation to immediately fail inspection in most areas.
Are we talking about the rim joist between the outside wall, floor joists, and the foundation? Or floor joists under the floor?
