Not sure if I removed and installed the distributor right.
All I did was remove the distributor and remembering the general direction of where the rotor was pointing to.
Installing, was the reverse by inserting the distributor and making sure the rotor was pointing in the same direction.
I am removing and installing the same distributor, I just had to replace the internal ignition coil.
NOW reading the manual, I saw that I must align the marks on the lug and the protrusion on the distributor.
Is this necessary or is it the technical way of saying make sure that the rotor was pointed in the same direction (cylinder) before installing. I noticed you can't put the distributor in all the way unless the rotor is turned to where it was last positioned anyways. ALSO, I readjusted the timing afterwards, since I didn't mark the distributor housing.
