The fast idle is for inching forward or backward on an incline. The 4.3 does not have any low-end torque at all, I have a 3.23 rear and the NV3550 transmission does not have a granny first gear, so it is like you are constantly starting off in second. I like the 3.23 for the fuel economy, at 60mph the engine is only spinning 1650rpm but it takes quite a bit of clutch slipping to get the truck going. It is difficult to modulate the engine speed with the throttle when you are inching back up a steep incline and I end up using more revs than is needed and therefore causing unnecessary wear on the clutch. With a fast idle switch at least the high rpms will be controlled. I had a fast idle set on my previous truck which was carburetted and I used a GM fast idle solenoid to hold the butterfly open a bit.
