Hi Everyone,
So after being talked down from going to a Chrysler, I wanted to get some input on a few enhancements I'm considering to my 2011 Corolla, to see what people thing is worth it/not worth it. Please note that most/all of the work will likely be done by someone, as I am not too mechanically inclined, nor do I have the facilities to attempt certain work.
1. Bluetooth audio system upgrade. I'm calling dealers to see if it is possible to get the OEM one with steering wheel controls installed. We will see, as Toyota is pretty bad about making these things available. I was going to go with an aftermarket Rosen stock-look HU w/Nav, but decided against that.
2. Replace wheels/tires with OEM 16" alloys. Would this make a difference performance/drive wise, or would I be better off with 2.5 below
2.5. Just get new 15" tires to improve ride quality (the wheel covers/steel wheels look ok enough to me).
3. Auto-dimming rear-view mirror. I found the OEM toyota one online, but it is screwed to the windshield. How hard is this to replace? Is it battery powered, or does it have to be wired in somehow? Would this be difficult?
4. I can't seem to find OEM fog lights, which I would like.... But I'm hearing these aren't really worth it beyond looks (which isn't important).
5. I'm going with Denso wiper blades (OEM) to fix the nightmare I have with every aftermarket brand.
6. Finally, I was looking into getting a tire pressure monitor and portable compressor, is this a good idea to check tire pressure twice a month to ensure fuel economy/ride quality, or would that be overkill?
Thanks for any insight, I've learned so much from so many people with great input on here!
