My 94 Land Cruiser 392,000 mi, has had cold inconstant start up smoke for the last 100,000 miles or so.
That is, some times when starting cold, I get a blue cloud of smoke and other times starting cold there is no smoke. The length of time and outside temp and the same when it does and doesn't produce a blue smoke cloud. Its not a big cloud and it goes away fast.
Could it be that the motor has to stop at a certain location for there to be oil leaking past the valve seal? Assuming its the valve seals that are leaking. Having never worked on valves or heads, could there be a warn spot on a valve stem instead of a worn valve stem seal? Or is it normal for leaking valve stems to only leak at certain points when the motor stops running?
