So I had a situation last night, and its the second time this has happened, where I was on ice and the limited slip in my CVPI turned into an open differential and everything went to the driver side tire.
I has on an incline pointing downhill and was trying to reverse back up it. My friends car was parked in front of me so no going forward either. In fact, trying to work it out I slid into his bumper.
This happened before on flat ground too with ice where I was trying to back into my garage and got stopped on the ridge of ice at the garage door.
I rebuilt it with fresh clutches and steels about 10-12k miles ago. So I dont think they are worn out. I used only Valvoline Synpower. I didnt need to add any FM along with it to keep it from grinding in normal use.
There is a part number for a F150 clutch preload spring that is heavier than the car springs, but I don't know if it would actually make a usable difference. Any one have experience with the F150 spring vs the Car spring?
The other thing I was thinking about doing was fixing my parking brake. KCSO never used the park brake the whole time they had the car, so the cables are seized. Unfortunately they worked well enough once for them to get stuck ON shortly after I bought it and I smoked the shoes so I need to source cables and shoes to fix it.
I think that if I couldve tensioned it with the P. Brake, I mightve been able to get it to lockup better.
Thoughts?
Oh, I have Altimax arctics on the car.
Thoughts?
