The vehicle in question is a Kia Forte 2.4L 6 MT 125K with 4 wheel disc brakes with parking shoes inside of rear rotors, It has abs, electronic brake distribution, brake assist system and stability/traction control. I don’t think any of that matters because this is a mechanical parking brake I’m asking about.
I was thinking this would be an easy fix/adjustment but I was wrong. The E brake/parking brake in the forte does absolutely nothing, I adjusted the tension in the center console and then took off both rear tires and adjusted the parking brake shoes that way via the hole in rotor, adjusted with slight drag but even with the adjustments, pulling up the handle as hard as you can in the car, does not engage the parking brake . The handle does not even go up all the way, I adjusted to factory 5-7 clicks. and with as much strength as you can put into that handle the parking brake does not engage and goes up about 6 clicks max. It gives the feeling with the resistance in the parking brake handle that it’s working but it’s not. 😔
What should I be looking at here? I do plan on upgrading the brakes rotors and pads in the next couple months, should I just replace the parking brake hardware while I’m in there? I’m really getting the feeling that somebody drove with the parking brake engaged and that’s why it’s not working. The cables are also free and do not drag. The odd thing though is if I adjusted the parking brake through the rear rotor I could get the tire to lock up with that adjustment, but even doing the factory specs with slight drag and 5 to 7 clicks max the parking brake completely unresponsive. Thanks in advance for all your input and suggestions.
A couple pictures after chemical guys ceramic wax treatment for your enjoyment 🎉
