ILSAC GF5
4wd
$50 site donor 2026
Texas/Other via IAH
Bought several Mobil 1 six packs at Costco - helps me top off behind the Walmart jugs.
Changed Cruze just now with 2 x 5w30+ 1 x 10w30 and 1 x 5w30 HM ... (Leak started at 67k)
Only the HM was not ILSAC GF5 ... Is that typical or could it be an older six pack ?
That Mobil 1 High Mileage is good stuff.
At the thick end of the grade, with higher HTHS and higher zinc. A good performance oil.
Regular Mobil 1 5w30 has a HTHS of 3.1 and 900 ppm zinc, while Mobil 1 5w30 HM has a HTHS of 3.3 and 1100 ppm zinc.
Not ILSAC, but a very good oil, to my mind the Mobil 1 High Mileage oils are the pick of the bunch.
Good info - the PP looks to be leaking faster from my 5.3L GM at rear seal - so I could start rolling in the Mobil 1 High Mileage next change @ 62k - bit early in theory - but a 2010 that see's on/off work ...
Basically it has to much of the good stuff ZDDP to be GF5. Think of it as Poor Man's Redline.
And Maxlife HM (red bottle) is the poor mans VR-1
