This is similar to another thread, but I didn't want to hijack that one. We moved, this summer, into a house built in 1996. At the time it was built, the ventless gas inserts were extremely popular. It has the "doghouse" fireplace bump-out commonly seen on homes built during this timeframe. There's no flue or chimney -- just a constructed bump-out in which the insert lives. This is not our house, but we have the same type of bump-out:
The pilot is difficult on ours to night, though I think the thermocouple works. We honestly haven't used it at all (except for during our pre-purchase walk-through) because I don't care for such a ventless system running in the house. I've since read that these types of systems are generally no longer installed and, in some cases, are not even allowed in new construction code. In either case, we're looking at options.
I know I can convert it to a direct-vent insert. This effectively closes off the fireplace system from the room and uses outside air for intake and exhausts all air to the outside as well. These are convenient (push the remote and they turn on), but a retrofit will likely be in the $5000-8000 range, depending on the model we get.
I'm also considering wood pellet stoves and/or inserts. These are tremendously popular around here. For this solution, though, wouldn't we have to have a flue constructed? The wood pellet systems themselves aren't all that expensive (sub $2000), but we're not sure if it's really feasible given the construction of what we have.
We don't want anything electric, since the idea is to be able to produce heat in the event of an electrical failure. From this regard (staying on-line in the event of utility failure), a wood pellet stove is most appealing (what if you don't have natural gas, either), but we're still not sure if it's feasible.
Any ideas for conversion of our existing ventless system? I imagine this has got to be a common thing (what to do with these ventless inserts as they age out of working right), but I can't seem to find a whole lot of information out there. I know some of you all will have some great ideas!
Thanks.
Thanks.
