YOUR WHEELS
Even with warning systems, tires still need some TLC
By Ralph Vartabedian
Times Staff Writer
September 6, 2006
Nothing but compressed air, certainly not the rubber tread on the tires, keeps your vehicle suspended over the road.
So, the amount of air in the tires is vitally important, a fact that is relentlessly driven home by safety experts but ignored by many motorists.
After more than 80 people died in Ford Explorers that were equipped withpoorly inflated Firestone tires in the late 1990s, Congress passed the
Tread Act, mandating, among other things, that auto makers install tire pressure monitoring systems on future vehicles. Currently being phased in, the act will require all new cars to have such a monitor by September 2008.
But as implemented by the National Highway Traffic Safety Administration, the rules were quickly assailed by critics for a weak and ineffective
approach to the problem.
Since 2000, the issue of tire pressure has become even more critical, as motorists opt in increasing numbers for low aspect ratio tires that depend
on closely monitored air pressure to avoid blowouts caused by potholes and other road hazards.
A close look at tire pressure monitoring systems shows that, in general, they will fail to relieve car owners of the burden of closely watching
their tire pressures. While they may help to alert people of dangerously low air pressure, they will generally not warn drivers of air pressure low
enough to cause slow tire damage.
Two basic types of technology are used in tire pressure monitoring systems, or TPMS: direct and indirect. The less expensive approach adopted by
some auto manufacturers is called "indirect" and uses anti-lock braking systems to provide signals for the system.
When a tire has low pressure, it tends to rotate at a slower speed than the other tires, which the anti-lock system sensors and computers can
detect. All auto makers have to do is create some software and put a warning light on the dashboard.
But Clarence Ditlow, executive director of the Center for Auto Safety, said these systems "are wrong 50% of the time." Ditlow, along with the
Washington-based consumer group PublicCitizen, sued the NHTSA and won a judgment that the agency's rule did not satisfy the intent of the Tread Act. But ultimately, the agency issued a rule that still left safety advocates
and some members of the tire industry fuming.
Even the system's core mission - to warn of dangerously low air pressure - has loopholes under the NHTSA's final revised rule issued last year.
The system does not have to detect low air pressure for a full 20 minutes after a tire begins to lose air, for example. The loophole was put in to accommodate the limits of technology in the indirect system, according to Gerald Donaldson, a safety expert at Advocates for Highway Safety in
Washington, D.C.
Another key shortcoming of NHTSA's rule is that the systems are not required to tell the driver which tire is low, only that one of the four tires
has a problem. Donaldson, among others, said the lack of specific information could lead some motorists to ignore the warning.
The second type of technology is called the "direct" system and uses independent pressure sensors inside each tire stem. The sensors have
electronic transmitters that can send more reliable air pressure data to the car's computer. While an indirect system might only cost a few dollars, a direct system could cost $50 or more for all four tires, according tire experts. Most, if not all, automakers will opt for direct systems by 2008, experts say.
With both types of technology, however, the NHTSA set up rules that significantly compromised the effectiveness of the systems, critics say. The
standard calls for warning the driver when the tire pressure drops 25% below the level recommended by the vehicle manufacturer.
"One of our concerns is that it gives the motorist a false sense of security," said Matt Edmonds, vice president at Tire Rack, a major Internet
tire retailer that has long conducted independent testing of tires. "The unfortunate part is that with indirect systems you can get a false warning.
Then there is no confidence in the system."
Tire manufacturers set maximum inflation ratings for their tires, but it is the vehicle manufacturer that decides the recommended inflation for a specific vehicle.
Many vehicles, for example, have a recommended pressure of 32 pounds per square inch (psi), meaning the TPMS would not notify the driver until
the pressure dropped by 8 pounds per square inch to 24 psi. In some extreme cases, such as the older Ford Explorers, tires carry recommended
pressure of only 26 psi, meaning the warning system would not alert the driver until the
pressure was down to 19.5 psi.
Donaldson said the NHTSA should have required a system that notifies a driver when pressure drops 15% or 20% below the recommended level. An NHTSA
official said the agency was concerned that if drivers were notified of low pressure too often, they would begin to ignore the warnings, terming it a "nuisance." The 25% level was selected because it provided a warning of "extreme danger," according to an agency spokesman.
But by the time pressure drops 25%, the tire is undergoing damage to its internal construction, according to experts.
Bill VandeWater, consumer tire products manager for Bridgestone, said tire damage begins when pressure drops 5 pounds per square inch below the
vehicle manufacturer's recommendation.
"Five pounds per square inch is a good rule of thumb," he said. "We would never like to see it go less than 5 pounds below the level recommended
by the vehicle maker."
After the NHTSA issued its final rule, the tire industry sent a letter explaining bluntly what it thought: The Tire Industry Assn., a trade
group, said it believed the final rule was "fatally flawed" and added, "This final rule will not keep the motoring public safe."
The upshot here is that the consumer is still responsible for crouching down at least once a month and measuring the pressure in each of the tires on his or her vehicle. It seems to me that if consumers are willing to pay for such
creature comforts as power windows, leather seats and compact disc players, they would also pay $50 for a system that would give a digital readout
on their dashboard of each tire's pressure.
To make your life a little easier, I suggest buying an inexpensive air compressor for your garage. Having your own compressor is a lot better
than fooling around with cruddy hoses at the gas station. Basic compressors cost as little as $60 and are useful for all kinds of other projects. Like blowing the dust off your car's owner's manual.
[email protected]
Copyright 2006 Los Angeles Times | Privacy Policy | Terms of Service
Home Delivery | Advertise | Archives | Contact | Site Map | Help
