If you cannot sell it to a collector, just recycle it.
Computational wise everything up to probably Pentium III can run DOS backward compatible enough and still has those serial parallel and floppy disk support in BIOS to do everything this thing does, 10000 times faster. There's also PC104 board that are faster and newer than this that's already obsoleted and scrapped and fit on your palm.
If I remember right the silicon's doping and metal stuff only last about 10 years reliably, at 30 years those stuff will likely make errors if you run it, even if it was powered off for the last 25 years.
