Originally Posted By: d00df00d
Originally Posted By: phlfly
Also as I said before have you ever see Synt oil for about 6 bucks and more important export from Europe? A good Synt oil is cost around 10 bucks that made is US. I guess Euro Castrol should be around 12 bucks.
BMW's 5w30 is used by ALL BMWs except for diesels, certain very old models, and certain M cars. BMW gets it in very large quantities. Their marketing budget for it is zero. Its distribution requires little that BMW doesn't already operate. There are all kinds of reasons why the price can be low.
Moreover, the "good synthetic oils" that cost $10 per quart are all from smaller companies that don't have good economies of scale, or from companies like Motul that don't have much mainstream distribution in the US. A better comparison would be the $7-$8 synthetics on store shelves. The price difference between those products and BMW 5w30 is easily explicable in terms of BMW undercutting the mainstream brands to help make sure their customers use the right oil.
Bottom line: Price is a horrible indication of how good an oil is.
Incidentally, BMW also sells Castrol TWS for high-RPM M cars, and that oil actually does come from Europe and cost around $12/L...
And those High RMP car has vanos problem. Ask me how I know. I only used 10W60 TWS. Well result bad. Metal craked and teeth fell to oil pan. Good luck to use this oil again. Those car design bad too much heat and bad oil flow will kill you engine eventually.
