Originally Posted By: El_Schaf
Its all 5w30. Oh, and I wont be towing at all. I suppose, if it will actually clean things, I am not at all worried to run it for a week. I was more worried about additives mixing and reacting poorly, sort of a mixing green and red antifreeze theory.
I would suppose if it is not going to react poorly, it would probably be a better lubricant than MMO or seafoam.
Nothing bad will happen. I spent 23 years working at an equipment rental company and I can tell you as a fact the only really bad thing that you can do to an engine is run it with out a proper airfilter. We experimented with various oils in auto transmissions, in engines,and hydraulic systems etc. and the big thing that killed engines was no air cleaning. Dirt is the enemy! I keep my service van running till the boss made me turn it in for another one by thickening the oil with 90 wt gear oil to quiet down the knocking. I charged off the 90 wt to the rental dept because STP would't pass the rental dept managers ok.
