Originally Posted By: Oldasco
I don't fully understand Hyundai's TSB recommending using only their brand oil filter...are all oil filters other than Hyundai OEM oil filters flawed, or is the design of Hyundai vehicles flawed. If I use a Purolator oil filter instead of a Hyundai OEM filter in my new Sonata, is the engine going to blow and me getting stuck with a non warranteed financial mess.
This TSB has been discussed in numerous threads here in the past to the point of ad nauseum and gets misconstrued in so many ways.
The first fact is the TSB is written for dealership service advisers and mechanics, not the general public. It only advises what the dealer service department is to do in case of any of the symptoms as mentioned in the TSB. If replacement of the filter with a KIA/HYUNDAI OEM filter fixes the customer complaint, then it is obviously not a warranty issue and the customer is charged accordingly.
The TSB does not say that you can not use and aftermarket filter, just that they only recommend their OEM filter as that is the only one they test for their vehicles. You would get the same line from Ford/Motorcraft, GM/AC-Delco and any other vehicle maker.
KIA/HYUNDAI can not deny warranty claim for just the simple fact of finding a aftermarket filter on your vehicle, they have to prove that the aftermarket filter actually caused the damage in question. Use of a OEM filter removes this shadow of doubt though. If KIA/HYUNDAI actually required 100% compliance of OEM parts to maintain warranty, then by law they would have to provide that part for free and the last time I checked, my local KIA was not giving out free filters.
The simple fact is that not all filter makers have correctly applied or made a filter to meet the requirements of KIA/HYUNDAI but have cataloged some filters that just "fit" and seem close enough but are not always foolproof. These are usually easy to spot when it is the same filter part number that is used on mid to late 1990's Honda 4 cylinders that have lower bypass specs than what the KIA/HYUNDAI engines require.
