I need to do a sump drain and refill on my Hyundai Trajet automatic transmission box. I know a lot of ATF is held up in the t/converter and will not drain out simply by doing a sump drain. The box contains 8 1/2 litres of fluid.
Questions;
(1) Approx. how much fluid will drain out by draining sump.
(2) After replacing the ATF drained out how long should I run engine for to drain out the ATF from t/converter before doing a second sump drain and refill. I want to avoid disconnecting return pipe from t/converter
Would appreciate some suggestions
Questions;
