- Joined
- Dec 2, 2020
- Messages
- 5
Hi Guys, Can someone explain what is difference between the two. ?
A quick Google search shows hundreds of websites and videos on that topic.Can anyone go into more detail and explain the technical of hydrostatic drives meaning? . What is the term hydrostatic mean? Does UTTF comes under Hydrostatic oils category?
its basically variable propulsion with a fluid and pump the other option is some sort of clutch or belt drive.Can anyone go into more detail and explain the technical of hydrostatic drives meaning? . What is the term hydrostatic mean? Does UTTF comes under Hydrostatic oils category?
Hydro= water/ fluidCan anyone go into more detail and explain the technical of hydrostatic drives meaning? . What is the term hydrostatic mean? Does UTTF comes under Hydrostatic oils category?
It depends on the manufacturers recommendation. My compact tractor uses the same trans oil in the gear transmission and the Hydrostatic transmission. The movers use what ever engine oil that meets the temperature of the climate and operating temps on the viscosity charts.Can anyone go into more detail and explain the technical of hydrostatic drives meaning? . What is the term hydrostatic mean? Does UTTF comes under Hydrostatic oils category?
What are you using this in? In a small tractor, usually you need UTTF or UTF like Spirax S4 TXM which is fine for a hydrostatic transmission, the hydraulics, final drives, and wet brakes. I wouldn't use plain hydraulic oil in a tractor due to lack of additives for the brakes and final drive, but I would use UTF in a simple hydraulics system in a pinch as the additives won't likely bother anything.Can anyone go into more detail and explain the technical of hydrostatic drives meaning? . What is the term hydrostatic mean? Does UTTF comes under Hydrostatic oils category?
