I have the transaxle removed from my Husqvarna YTH20K46 lawn tractor to repair broken mount that axle bolts to. It is equipped with the hydro gear T2 transaxle. Thought I might drain and refill the fluid at this point with almost 400 hours on the unit. I managed to find a service manual that says I need just over 2qts of 20w50 motor oil.
It seems to be a straightforward procedure. Anybody on here ever done this before? Is it worth messing with or is this one of those things better left alone?
If I decide to do it, I was considering maybe some NAPA 15w50 or Mobil 1 15w50. Would one be better off using 20w50 conventional or perhaps a motorcycle oil?
