Originally Posted By: George1954
Originally Posted By: spasm3
IF it goes away after warming up, i would think the thinner oil is flowing better through the lifter. If may have a plugged/partially plugged oil hole. I would try an oci of mobil hm synthetic. It cleans. Thicker oil may make it worse if the sound is more noticeable when the engine is cold( when the oil is thicker).
Do you suggest one or more OCI's with a high "clean up" oil and return to PYB or make a permanent switch?
I tried to figure out the cause based on the fact that the noise was showing back up at the end of the OCI but there are too many moving parts in the equation. The oil is most likely becoming thinner and then eventually, thicker. Also the additive package is breaking down, the filter is filling up, etc. Because of this I was thinking of trying to get to the bottom of it thru some trial and error (thinner oil, thicker oil, more detergents, synthetic, higher flow filters, but I figure you guys could help me pick an intelligent starting point.
Don't decide now, run the m1 high mileage and see how it does. If it helps the problem, keep using it. If it does not help then back to the pyb.
