I've got a 2-ton MVP jack like the one pictured here:
It worked fine for 2 years, but after my last move, it stopped lifting. I thought maybe I need to bleed the air out of it, which I did using some instructions I found here . If this is not correct (I lost the manual for this jack), please let me know what is.
I also checked the oil level - everything seems to be fine. When I don't put much load on it, it will lift, but when I put it under the car, it won't. What else can I check? A busted seal somewhere? Didn't see any...
Thanks!
Thanks!
