Well, the septic took a clog so I'm spending the morning digging it up. Got 2 of the three access holes open, and stuff flowing properly, and will have it pumped this week I think (its due). I recall last time the septic guy indicating I need to seal up around the inlet with hydraulic cement, as worms were crawling in. I, err, never got around to it.
I have a bucket of anchoring cement; once the tank is pumped (or if the water line stays below inlet), that should be fine, right? Best I can tell, hydraulic will set faster which is good if under/around water; anchoring cement expands a bit, which is neither good nor bad here.
I haven't dug around the pipe just yet, but I assume it's just a loose fit.
