Well I tried this oil additive due to reading about it on here. MolaKule stated it was a real deal additive that was actually worth using. Being the fact that MolaKule is one of the most knowledgeable people on this entire board (top 3 in my book) I felt very comfortable giving g this a go in the lady's Camry. Well between adding a whole 12 ozs of this Hy-Per lube and Federated Auto semi synthetic oil the motor was MUCH quieter than it had been on a 50/50 mix of Super S and Cam2 5w30. Very interesting was when the car was started right after changing the oil was the first half second the motion had that loud ticking... Then after the new oil and Hy-Per lube hit the top end of the motor... Way, way quieter. I am impressed. So.. if you got a loud motor.. give this Hy-Per lube a try. Ohh and only add 1 oz per qt of oil. Which I way over did it in this situation. So, when I got another bottle of Hy-Per lube it will be good for 3 oil changes in the 98 Camry. Got it on sale for $15. Between the cost of the Federated Auto semi synthetic oil and the Hy-Per lube it works out to $14 per run. Not too shabby
And when I did a drain and refill of my CVT fluid I will be getting Amsoil CVT fluid. Again because of MolaKule's help and recommendation plus cronk running it with no issues in his Nissan.
