All,
I have a 2000 Ford Contour with 144,000 miles and recently it's been doing this "hum" from under the hood.
If I rev the engine it goes away, but the hum usually happens at idle or a little above idle and is random.
I know that the power steering pump is powered by the belts but what about the brake master cylinder? Is there a pump that operates it?
I had the power steering pump replaced about 2 months ago b/c it had a small leak so I don't think it's that.
However, I had the brake system flushed by the dealer just the other day and it started doing that hum not long after that. Also, this hum had occurred about 3 times in the past, usually when the engine was cold and just started. I'd tap the brake pedal hard and it would stop.
Could it be the antilock brakes motor activating?
Also, I asked the service writer at the dealer, who I've gotten to know pretty well, unfortunately, due to having to replace most everything on that car except motor and transmission, and he said that the brake fluid looked decent and that it wasn't terribly bad.
Thanks,
Karl
Thanks,
Karl
